Re Audio SE12
nags
I've been doing a bit of searching around here and I've seen numerous people highly recommend the SE12. I'm looking for a new sub to match up to my ESX Q1752 and it seems like it'd be a good choice.
I'd be running the amp at 500x1 at 4ohms. That would mean I need the 2ohm model, right? I've always used sealed boxes in the past but everything I've read says the SE shines in a ported box. Can you guys recommend and premade ported boxes that'd be good for this sub?
I'm also not dead set on this sub yet, so if you have any other suggestions I'm open to them as well.
I just found a store that has the D2's in stock. So back to my original question. .. The D2 would be the proper match for my amp? And also I need to find a good ported box for this thing.
they'll take more than 600w, but yes, it's a good match. I did 1.8 @32 and liked it.
ive tested the se's in both sealed and ported with ~500watts. sound great in both, smooth and clean. of course the ported was louder. sealed box was 1.5 before displacement and ported box is somethin a lil over 2.0cubes tuned upper 30s i believe.
We all know what plays better in a sealed box:D
Sounds like my mind is pretty made up.
Just gotta find a box now
Thanks for the help
Idk what you plan on getting but i would get one made or make one for yourself. It is not hard with the proper tools.( table saw, or circular saw, jigsaw, and a few other small things) Good luck.
nags
nags
South Florida
nags
