way2sl0
I am designing a box for a Single 15" RE SRx.
I have decided that ported is more efficient, even if I tune it low ( 28-32hz ) over sealed that will give better output.
When im using the RE box calculator however, I dont know if the calculations take into effect the box's tuning after the port displacement or before? Also I know for sure it doesnt take into account the driver's displacement.
One last thing. My trunk has 16.5" of clearance to put a box in, however my sub is like 15.4" high (outer mounting) so having the MDF that thin on the ends, is it going to be a problem? Thank you for your help in advance,
Matt
Matt
