RE AUDIO re series 8'' Dual 4ohm
If I remember correctly these are the SE series. The subs were in a custom install that never got finished, they never saw over 100 watts rms (1/4 of the volume) due to the nature of the install. One sub has a bit of the hard foam cut off (about an 1" in length) and the other sub has 2 extra holes drilled on it. Mechanically these are 10/10, cosmetic I say 8/10.
Product Dimension 8"
Mounting Depth - 4"
Mounting Hole Diameter - 7.125"
Overall Diameter - 8.25"
Bolt Hole Circle - 7.75"
Motor Width - 4.875"
Motor Depth - 1.5"
Basket Depth - 2.5"
Displacement - 0.07 cu. ft.
Weight - 6 lbs.
T/S Parameters 8"
Electrical Q Value -Qes: 0.38
Mechanical Q Value -Qms: 4.21
Total speaker Q Value -Qts: 0.34
Free Air Resonance -Fs: 22.8 Hz
Equivalent Compliance -Vas: 27.1 liters
One-Way, Linear Excursion -Xmax: 12 mm
Efficiency -SPL 1W/1m: 81.2 dB SPL
Effective Piston Area -Sd: 195 cm^2
DC Resistance -Re: 3.2 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 175 W
Force Factor -Bl: 15.4
UPDATE!! Kicker Impulse x3i Crossover. I just found this crossover in my garage, it was working the last time I used it. However, I will be testing it just to make sure it works. I'll include with the SUB's for an extra $10.
$85 shipped for the pair plus $10 if you want the crossover.
Mounting Depth - 4"
Motor Depth - 1.5"
Basket Depth - 2.5"
Weight - 6 lbs.
T/S Parameters 8"
