rd1750 vs aq2200
msand951
which amp would you get? is rd underrated. Can you give me some info on why to get which one like which is more stable, power hungry, etc. i want to sell my revo 15 to get a 18 alpha. and want to power it with one of these amps. but until i sell my revo im going to use it on the revo.
the rd's are OVERrated. they have the same boards as the 1500 from sundown dont they?
you never used the 1750s? the board they use is the same as the 1500.. it has 8 300 watt transistors... they are good amps.. its capible of 1600@ 12.5 volts, and 1750@13.5 @ 14.5 you can expect 1900-2000 or so.. honestly id take the rd 1750 before the aq.. i like the aq for burps, but for music RD... btw for a hundred more sundown 2000d will eat both alive..
Well, the sAZ-1500 was tested and did close to 2k watts at 1 ohm below 14 volts IIRC..so technically you could say the 1750 is overratted but will still do more than rated if its around the same as the saz-1500
how can you say its overrated, i was able to get 2100 out one 1750 with a 1.1ohm load, but it sounded like ass.. im not into power output with a thd above 1%. the figures i gave are still linear. NO doubt for music the rd is superior.. the sundown is very similar, there ratings are just @ 12v VS 13.5. on a normal 14volt charging system id expect 1800 out both amps.. and about 1800-1900 out the AQ as well...
db-r has said multiple times that the AQ2200D and Sundown 2000D are pretty much the same amp, so saying it will eat both alive is incorrect, and the AQ had been proven to do rated or even a tiny bit over with right electical
I have not owned or messed with an RD amp. But when I had a pair of AQ2200s i was nothing less than impressed with them. And for whoever said that they sound like **** daily you either have a bad setup as far as sub or enclosure go or something else. Cus it sounded better as a daily amp than most of my friends high def amps. I would go with an AQ Im pretty positive you will not be unimpressed.
Many of the "facts" you have listed are wrong.learn alittle more before posting false ****.The AQ2200d WILL take both the rd1750 and sundown 1500 for dinner.search around
The RD 1750 and the SAZ-1500D are similar/same inside. The design of the Aq2200D is the same, they just added a few more power supply and output mosfets to make it produce more power, but it works the exact same way and uses the exact same parts.
Only some differences are possible between these boards, maybe the components used in the input circuit, and the quantity or quality or both of the capacitors used in the amp, but in real life that stuff gives the manufacturer something to claim that his product is better is some way than a similar product, but really doesn't make that much difference in the sound quality or performance of the amp. So to say that any one of these three amps sounded bad was probably due to some problem with the install or the listeners ears, not the amp itself, as they are so similar that the only difference would be power output in the AQ2200 which would exceed the RD1750 or the SAZ-1500D, but would be equal or very similar to the SAZ-2000D. No SQ differences should be notable, if they are in fact producing different sounds, it should not be detectable by the human ear.
The new RD 1750.1 is no longer all that similar to the SAZ-1500D... FYI.
msand951
msand951
san jacinto
ninjawhiteboy12
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
