Sold RD d9 for $500 shipped obo!!!!
kowboy
SOLD!!!
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
SpecificationsRMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
I accept paypal only, and my refs are impeccable...lemme know guys...thx!
Will also sell it blown for $250 plus shipping if you wanna have it fixed yourself(although I'm not sure if that would void the warranty or not)
i like the Sundown Company. Jake and Scott always gets back to me at least by the end of the day(if they are that busy).Even though i had problems with my sundown 3000ds in the past i will most likely buy one of there amps or subs for daily because they are well built cheap(but not crappppy cheap)well actually not cheap affordable amps and subs.
Ditto...my next amp purchase would be a 4500d if they didn't cost an arm and a leg and my first born, lol!
if u got it in preorder would be cheap.Was $1000 shipped when first came out and now its gonna be more but well worthit and a must have if u are a Sundown Audio Fan.The 3500ds aint badd at all the price and built just lookin at the testing they came out with from all audio sites
yeah, I guess you're right - I'm just poor! I have to wait until they're not so new. Maybe catch a used one for $700-$800, lol!
nah i will be doin that too we aint all that rich and car audio is not cheap.If it was we all be averaging 150s.160 would need more dedication like ripping your whole vehicle apart just for the build from carpet to panels.
whoever scores this will be very satisfied if i dont.Been wanting one ever since i seen what it can do which one is run daily at .5ohms without a problem so long u got electricals
All day //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif I run one on a pair of HWs at .5 ohm right now and its rock solid.
kowboy
kowboy
The "D"
danyopjr
