Sold RD d9 for $500 shipped obo!!!!
kowboy
SOLD!!!
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
SpecificationsRMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
I accept paypal only, and my refs are impeccable...lemme know guys...thx!
Will also sell it blown for $250 plus shipping if you wanna have it fixed yourself(although I'm not sure if that would void the warranty or not)
It's half off on caco......
http://www.caraudioclassifieds.org/forum/showthread.php?t=26655
Rd d9 for $250 plus shipping...
1. Product:
Rd audio d9
2. Specs:
Features
T.H.D @ 4 ohm
3. Description/Condition:
Blown, but cosmetically 9/10...
I bought it from rd about a month ago, and it's under warranty... I can send it to be repaired and it won't cost me a dime, but I'm tired of waiting, so I'm just gonna sell it blown...
$250 plus shipping
Then again shipping could be $250
Sorry if I went all Michaellane //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
$250 plus shipping
Read the OP again.
if you guys cant get him at his pm box. you can send your pms to me. pming me you may have faster results as im dealing with him directly/ and im on the pc more than he is.
kowboy
kowboy
The "D"
danyopjr
