Sold RD audio V1 3250.1 V1! First $420 shipped.
hornedfrog1985
<---Down Syndrome Tiger.
$420 shipped, and insured.
The RD series amplifiers deliver a ton of power with a low distortion rate. We used the best parts we could find to give you a top quality amplifier that anyone would be proud to show off. With their clean looks and sleek finish, they’ll look good in any install. So whether it’s an elegant sound quality setup or a high powered SPL vehicle, the RD series amplifiers have you covered.
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Double sided through hole epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24dB/oct variable crossover
Variable subsonic filter
Variable bass boost
Variable low pass filter
Variable phase shift
Efficiency : 86% @ 4 ohm, at 100Hz
Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
RCA line input
Tested voltage & THD : 14.4V & less than 1% THD
Operating voltage : DC 10V~18V power input- 2008 models
Wired remote controller
MSRP
$1399.00
Specifications
RMS power, 2 ohm linkable/dual mono 5600w x 1ch
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 590(L)mm
Manual: http://www.rdaudio.net/RDAUDIOmanual_final.pdf
hornedfrog1985
hornedfrog1985
Iowa
hornedfrog1985
