RD Audio, or MMats!?!?!?
Btw, if that mmats amp only has a 100 amp fuse, it would have to be 150% efficient to put out 2000 watts. And the RD has a history of amps going bad for no reason. Sooo.... buy something other than those two.
well that sucks. I need about 1800@ 2 ohms, to give two dual 2 ohm subs 900 watts each. which is why id was getting such a big rd audio amp. it's about 1500 watts at 2 ohms, and the mmats is a 2 ohm amp. options are looking bad now
See if the RD is a V.1 ....if so get it....Zenon board....and that price is way too much IMO on the mmatts....also...what's your electrical consist of?
toshiba transistors and 1% tolerance parts on hte mmats.. MMats are some of the best amps ive used.. i have a pair of the orginal 1750 there good amps, there noisy if your not careful but there reliable and strong.. if you don't need 3kw and 2kw is enough go with the mmats..
Mmats makes good shit...Their amps are typically super efficient, and super small for the power they put out. The older black models look very subtle too, which is a plus imo. The power is very clean, especially so on the SQ models (go figure). I'd get the Mmats just to be different...and because it's so efficient. Juggernauts are pretty well known, but I don't know of anyone who has heard of anything else related to Mmats...
only thing I know is that, they are efficient, they are one of the most reliable amps I can get, just like AQ, and the quality of the insides is great. The guy said its nothing that will blow me away, but I won't ever be unhappy. Good enough for me. I have to rockford subs, I just want to hit about 142dbs, and Ill be good
mmats uses 16v components internally and 120v rails, thats why they are very efficient and u need to find out if its black or silver if its silver it puts out 1500rms if its black it puts out 2000rms, mmats is one of the best amps u can buy on the market made right here in America quality stuff, not many things can touch them in efficiency and size.
its silver. 500$ would be the the wiring and installation. I have a hidding amp rack dropped in my trunk with glass over it. 500 is for it all
alexmarzouca
alexmarzouca
Florida
alexmarzouca
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
