RCA wiring
nemesismachine
I forget where's the best place for RCAs. I drive a 93 civic, and am running 3 sets for front rear and subs. theres a load of wiring on the driver side, and the power is down the passenger side. should they go down the center between the seat and the bottom under the carpet? im not trying to run em down the driver side and get mega feedback. any ideas?
Originally posted by nemesismachine I forget where's the best place for RCAs. I drive a 93 civic, and am running 3 sets for front rear and subs. theres a load of wiring on the driver side, and the power is down the passenger side. should they go down the center between the seat and the bottom under the carpet? im not trying to run em down the driver side and get mega feedback. any ideas?
Up the A pillars thru the roof Panel and down the b pillar to the trunk !
trust me Just run them with the power wires----------it's fine
it wont pick up any feed back from the wiring under the carpet on the drivers side? or should i hook it up first to check. the only reason i'm being picky is all the other systems ive put in have done it, and im pretty sure thats why.
up the a pillar??
Originally posted by nemesismachine it wont pick up any feed back from the wiring under the carpet on the drivers side? or should i hook it up first to check. the only reason i'm being picky is all the other systems ive put in have done it, and im pretty sure thats why.
up the a pillar??
it's not ---------- read the post called WIRE SIZE FYI
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
Having to adjusting the sub input sensitivity depending on the music, would be reason enough for me to go with the RCA cables. It does seem odd...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
671
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
674
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
592
nemesismachine
nemesismachine
Washington DC
chris229
    May 18, 2024
    May 18, 2024
