RCA Output
Quick way to check.
Grab a DMM, set it to AC Voltage, connect the red DMM lead to the center of the RCA wire and the black DMM lead to the outer shield of the RCA, then turn your deck up and play a test tone (I would recommend disconnecting all the other RCA's from the amplifiers, so that you aren't blasting your stereo during the testing).
With the deck turned up to ~90% of it's max volume, it should have an output of near it's rated voltage output.
This way, even if you do sell it, you'll know whether or not that preamp output works and can inform the buyer.
badandyturbo
Florida Bass
badandyturbo
South Florida
Death By Bass
