budahbuddy803
I made a thread not too long ago and all i got was an *** hole saying that it was the ground wire. I promiss you it is not the ground wire because i try other amps and it works perfectly. I have used different RCA cables and the problem is the RCA inputs on my amp. I will get the RCA snuggly into the inputs and it will be perfect and then i start driving and hit a bump and there will be a high pitch whine that goes along with the RPMs of my car. I jiggle the RCA next to the amp input and it goes away and will remain perfect until i hit a small bump. I tried to tape the rca in a spot where the noise goes away but im sure this will not last long.
My cousin said he saw something like wrapping some copper in a figure 8 around the RCA inputs.... will this help? Is there a special technique i should use. I am going to get a new amp because of this problem at christmas, but i am looking for a temp fix until december.
