rca in-line gain control
are there screws? just about everything can be dis-assembled. even if you have to crack the case with pliers to open it up and just use the board/pot. if you are any good at soldering, you could use the pot without a board, if utilized, and direct-connect the wires to the pot....
It's basically just a stereo potentiometer. If you need to make one just go to partsexpress and buy a dual 1000 ohm pot and solder some RCA wires to it.
I have one made by PAC I think and it's in a small plastic box that attaches with 2 screws. Hard to imagine anything smaller.
They come apart and the circuit inside is pretty small.
I had one apart and mounted in my dash bezel but I took the dash apart 1 too many times and broke the board.
Anyway I do not think there are any screws, it is pressed fit together - IIRC
goingdef
goingdef
Norfolk VA
>>SQL<<
vegang
vegang
