Need amp suggestion for 4 Pyle 8" subwoofers
well with 4 eights i take it ur goin for tha aww factor. Considering their pyle u mite get more like a aww heeeelll naaaw. Ur best bet iz to just let them look at it in ur trunk. I dont reccomend an amp because ur proly gona b dissapointed with the output.
well with 4 eights i take it ur goin for tha aww factor. Considering their pyle u mite get more like a aww heeeelll naaaw. Ur best bet it so just let them look at it in ur trunk. I dont reccomend an amp because ur proly gona b dissapointed with the output.
I would take the risk. I want to power these.
I need an amp that will power 4 Pyle 600W Dual VC (wired in parrallel as one) (4 ohms); My Lanzar MXA 284 barely move these at all.
I would recommend wiring them in Series/Parallel (all together) to be @2ohms Mono, be safer bet, than trying to find a dual 1ohm mono amp and or finding one that will handle a 1/2 ohm load Stable.Those subs are rated @300 rms each and DVC4ohm
I have them in parrallel, and my current amp is 2-channel, i have 2 subs on one channel, 2 on the other; i have no idea what ohms that equates to, and what im looking for when selecting an amp other than the max of the unit itself. Im not understanding this as every single amp cannot power over 400 watts on 4ohms channels, and i dont think thats the case.
//content.invisioncic.com/y282845/emoticons/offtopic.gif.470a8b0541c72322a0037f48a8237473.gif
OP is asking about an amp, not to be bashed for what he has...Not cool man,
Im gonna look up the specs for your amp....Lanzar still make fairly decent gear .
you need to be looking at RMS power not max
honestly id recomend selling those subs and buying something else. if you are dead set on keeping those subs you need to look for something that pushes 800-1000w RMS at 2 ohms
JoeK
JoeK
Ringtown, PA
Northstar
