Rattle Coming From Sub Itself
  • 4
Eldoggo
CarAudio.com Recruit
78
Canada
I've owned an American Bass 1044 with a Kicker HCP 1D amp. I noticed after a few days that from inside the car, the sub sounds beautiful, but when you pop the trunk and listen from the outside, there's a loud rattle coming from the sub. I made sure the gain is turned downed quite low on the amp since it's a bit more powerful than what the sub calls for, but it stills rattles. There's no bass boost from the amp or the head unit. Any ideas?
The gain knob isn't a volume knob so "turned down" doesn't mean much if you have an extremely strong source signal. Also when you say you have a rattle from the sub itself, do you mean the driver or vaguely somewhere inside the enclosure? If it's loud enough to hear over the music I'd recommend taking the subwoofer out of the enclosure and playing it VERY softly to see if you can tell what part of the driver is effected if any. A large number of things can cause rattle or noise from a driver, but most of them are going to be loose parts inside of the enclosure such as a basket plastic shell that's fallen off, a wire interacting with the cone, messed up voice coil/spider, or any number of other things.
If the driver is okay at low volumes and outside of the enclosure then don't go back to listening to music until you set up the amp properly either using ohm's law + a multimeter + 0db tones or just an oscilloscope/dd-10. Speaking of your amp, you listed it as Kicker but that model number corresponds to a Hertz amplifier. Are you sure it's Kicker?
Oh yeah, meant to say Hertz, my old one was a Kicker. I'll take it out and see what's doing it.
With power off, push your cone in slowly. If it makes any grinding or scraping noise, you likely have a fried voice coil.
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Example. H.depot or Lowes should have some also? or a hardware store
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Play the system when your muffler is cold and crawl under there and grab shitt until it quits rattling. That is really the only way to fix the...
10
Just when you think you're humming along... and... hmmmm happens!
22
Eldoggo
Eldoggo
Canada
jt4x4
slater
    May 2, 2024
slater
    May 2, 2024
