Rattle Coming From Sub Itself
Eldoggo
CarAudio.com Recruit
I've owned an American Bass 1044 with a Kicker HCP 1D amp. I noticed after a few days that from inside the car, the sub sounds beautiful, but when you pop the trunk and listen from the outside, there's a loud rattle coming from the sub. I made sure the gain is turned downed quite low on the amp since it's a bit more powerful than what the sub calls for, but it stills rattles. There's no bass boost from the amp or the head unit. Any ideas?
The gain knob isn't a volume knob so "turned down" doesn't mean much if you have an extremely strong source signal. Also when you say you have a rattle from the sub itself, do you mean the driver or vaguely somewhere inside the enclosure? If it's loud enough to hear over the music I'd recommend taking the subwoofer out of the enclosure and playing it VERY softly to see if you can tell what part of the driver is effected if any. A large number of things can cause rattle or noise from a driver, but most of them are going to be loose parts inside of the enclosure such as a basket plastic shell that's fallen off, a wire interacting with the cone, messed up voice coil/spider, or any number of other things.
If the driver is okay at low volumes and outside of the enclosure then don't go back to listening to music until you set up the amp properly either using ohm's law + a multimeter + 0db tones or just an oscilloscope/dd-10. Speaking of your amp, you listed it as Kicker but that model number corresponds to a Hertz amplifier. Are you sure it's Kicker?
Oh yeah, meant to say Hertz, my old one was a Kicker. I'll take it out and see what's doing it.
Eldoggo
Eldoggo
Canada
jt4x4
