I have a set of NIB Aura/McIntosh 8" subs. They make excellent midbass's also. Shallow mounting depth. $100 shipped. Not looking for trades. Selling to buy a set of motors. Here's the specs from madisound
Features:
Shallow depth
Good for autosound or in-wall
Underhung voice coil
NRT neodymium magnet system
Inherently shielded
Low bass in a small enclosure
Specifications:
Fs 35 Hz
Nominal Imp. 4 ohms
Power (RMS) 100 W
Re 2.65 ohms
Sens. 1W/1m 84 dB (2.83V@1m = 88.8dB)
X-max peak 3.5 mm
Qms 4.83
Qes 0.28
Qts 0.26
Vas 17.1 ltrs
BL 11.7 TM
Mms 64.2 gr
Cms 316 mM/N
Sd 196 cm2
VC diameter 50 mm
Their the middle set of speakers.
Features:
Shallow depth
Inherently shielded
Specifications:
Fs 35 Hz
Nominal Imp. 4 ohms
Power (RMS) 100 W
Re 2.65 ohms
X-max peak 3.5 mm
Qms 4.83
Qes 0.28
Qts 0.26
Vas 17.1 ltrs
BL 11.7 TM
Mms 64.2 gr
Cms 316 mM/N
Sd 196 cm2
VC diameter 50 mm
