Rare! Pg ti 900.7 rare!
3rdshiftdisc
Trunk Car Madness
1. Product:
Pheonix Gold Ti 900.7.
Full aluminum body. No steel on the thing. Rust proof and half the weight.
This thing is rare.
2. Specs:
RMS Continuous Power Output Into 4 Ohms:
50W x 7
200W x 2 (front, rear) + 50W x 1 (center) + 250W x 1 (sub)
RMS Continuous Power Output Into 2 Ohms:
100W x 5 (front, rear, center) + 125W x 2 (sub)
100W x 5 (front, rear, center) + 400W x 1 (sub)
Thermal Convection Cooled Heatsink (TCCH)
High-Current Triple Darlington Output Stage
Timed Acoustically Integrated Muting (TAIM)
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
Output Current Sensing Optimizes Power Supply and Output Stage
Intuitive Crossover Selection Switch Assures Easy Setup
24 dB / Octave Front and Rear High-Pass Crossovers Continuously Variable from 40 Hz to 4000 Hz
24 dB / Octave Sub Channels Low-Pass Crossover Continuously Variable from 40 Hz to 400 Hz
Auxiliary Outputs Route High-Pass, Low-Pass, or Full Range Signals
Twin-T Bass Boost Circuit Provides Up to 18 dB of Boost at 45 Hz
Superbrite Tri-LED Power-On Indicator
Independent Thermal and Overload Protection LED Indicators
Rugged Brushed Aluminum Finish
24kt Gold-Plated Power and Speaker Terminals
24kt Gold-Plated, 2-Ounce Copper, Double-Sided G10 Glass-Epoxy Circuit Boards
Replaceable Insulated Mounting Feet
Audiophile Grade Capacitors and 1% Tolerance Metal Film Resistors Throughout the Audio Path
Optional LPL44 Low-Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
Optional RMD Remote Monitor Display Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
Multi-Channel Amp SpecificationsAmplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 50W x 7 @ 14.4V
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 200W x 2 + 250W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >110 dB
Fuse Rating: 80 amps
Shipping: 14 lbs
3. Description/Condition:
awesome condition.
Cos 9/10
Mech 10/10
4. Price: :
740+ real shipping
5. Pictures:
great amp, i had a t1000.2 . I let a friend use it and he fu*k it up...
Last time i will let someone with no or very little exp use any of my very good amps....
glws man...
I like the MA Audio HK series ..ive ran and won with them at car audio comps
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
  • Locked
You said, "one of." How many do you have? I'm guessing that you are keeping the best one(s).
5K
3rdshiftdisc
Trunk Car Madness
3rdshiftdisc
Peoria, IL
3rdshiftdisc
    Jun 1, 2024
    May 31, 2024
