Rare! Pg ti 900.7 rare!
3rdshiftdisc
Trunk Car Madness
1. Product:
Pheonix Gold Ti 900.7.
Full aluminum body. No steel on the thing. Rust proof and half the weight.
This thing is rare.
2. Specs:
RMS Continuous Power Output Into 4 Ohms:
50W x 7
200W x 2 (front, rear) + 50W x 1 (center) + 250W x 1 (sub)
RMS Continuous Power Output Into 2 Ohms:
100W x 5 (front, rear, center) + 125W x 2 (sub)
100W x 5 (front, rear, center) + 400W x 1 (sub)
Thermal Convection Cooled Heatsink (TCCH)
High-Current Triple Darlington Output Stage
Timed Acoustically Integrated Muting (TAIM)
Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
Output Current Sensing Optimizes Power Supply and Output Stage
Intuitive Crossover Selection Switch Assures Easy Setup
24 dB / Octave Front and Rear High-Pass Crossovers Continuously Variable from 40 Hz to 4000 Hz
24 dB / Octave Sub Channels Low-Pass Crossover Continuously Variable from 40 Hz to 400 Hz
Auxiliary Outputs Route High-Pass, Low-Pass, or Full Range Signals
Twin-T Bass Boost Circuit Provides Up to 18 dB of Boost at 45 Hz
Superbrite Tri-LED Power-On Indicator
Independent Thermal and Overload Protection LED Indicators
Rugged Brushed Aluminum Finish
24kt Gold-Plated Power and Speaker Terminals
24kt Gold-Plated, 2-Ounce Copper, Double-Sided G10 Glass-Epoxy Circuit Boards
Replaceable Insulated Mounting Feet
Audiophile Grade Capacitors and 1% Tolerance Metal Film Resistors Throughout the Audio Path
Optional LPL44 Low-Pass Level Controller Allows for Driver's Seat Adjustment of Bass Volume
Optional RMD Remote Monitor Display Allows Monitoring of the Amplifier's Battery Voltage, Power-On, and Thermal / Overload Status
Multi-Channel Amp SpecificationsAmplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 50W x 7 @ 14.4V
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 200W x 2 + 250W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >110 dB
Fuse Rating: 80 amps
Shipping: 14 lbs
3. Description/Condition:
awesome condition.
Cos 9/10
Mech 10/10
4. Price: :
740+ real shipping
5. Pictures:
great amp, i had a t1000.2 . I let a friend use it and he fu*k it up...
Last time i will let someone with no or very little exp use any of my very good amps....
glws man...
3rdshiftdisc
Trunk Car Madness
3rdshiftdisc
Peoria, IL
3rdshiftdisc
