Rainbow vs Skar Audio
Make sure you count in your electrical in your budget
I am going to get 1/0 power wire to run the Big 3, as well as replace my battery. Then my sub, amp, and custom box. Everything is basically narrowed down, except what features i want in my box.
You'll find it quite difficult to damage an SA-12 or a VVX-12 on anything under 1kw of rated amp power... and even at 1-1.2kw of rated amp power per it is still not an easy task in a box even close to correct spec.
this last part is key with 90% of all subwoofers, and this is also what many "end-users" do not always do correctly.
So would they work better on the SAX-1200d or AQ 2200d. I don't plan on upgrading. So would the 1200d make more sense as I will get it for $40 less than the AQ.
Yea, in my old car i just had the generic box, wasnt an expensive system. But for my new car I want to get a great box to let the subs do what they were meant to do.
so i can put 2k+ on my sa15's?//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
No YOU can not, nor can that little mb quart amp. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
do the dimensions of my box play any role? Because I have no idea what size I would care to have the box. I have plenty of room in the back of the car.
desastrux
desastrux
Atlanta
denim
