Firewalker
CarAudio.com VIP
I am talking about the oem factory harness that was originally cut into. Would be interesting to see pictures of all of it just for the heck of it. Sounds like the wires are not connected correctly.
I have also had good fuses not pass current, until I pull and reinsert.I checked that and all of the fuses were ok
Ok I think that might be where the issue is, I really have no idea on how to wire things so I let my friend do it. As far as I remember in the new wiring harness there was not a ground so he tested all the wires and found one that wasn’t getting power so he used a butt connector to run the ground wire from the radio to that wire.Usually hard wiring isn't the thing to do. It looks like you have two different harness clips there. There are radio harnesses that connect those two clips together correctly. If it's not a fuse, I bet something there isn't connected correctly. You gotta be very careful hard wiring like that. You can really damage some stuff, if you give something power or a ground that isn't supposed to have it.
