radio help
  • 2
If ur car has a battery ad fuse box u can do it,The only prob is finding the correct wires from ur fuse box.It will take some time but u can do it urself easily,you will basically run wires from ur fuse box,using a voltmeter (Best) or a 12 Volt car bulb soldered to wire(Ghetto but works) From ur fuse box ur gonna need a ground, or u can use any bare metal chasis ground,a switched 12v ,red wire from hu,a constant 12v ,yellow from hu.to find ur swithed consult ur cars fuse diagram for what fuse is what ,and probe the fuse while turning ur ignition switch to acc, and then off,when the bulb goes off and on u have it.The constant is easy ,just probe till u have a constant supply of power.One word of caution,make sure ur radio will turn off and on with ur ignition to acc, otherwise u will kill ur battery fast.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Tex, if you have Sirius/XM, were you able to use your OEM antenna or did you have to install the one that comes with the kit? Good job on the...
28
4K
I have an XY Auto Android Radio. During day my phone connect and music works, and I can use steering wheel to control volume. That’s it though...
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
bronco2323
bronco2323
house
bronco2323
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
