RAAMMat Sound Deadener
crosjr
1. Product:
1 box of RAAMmat BXT II
3 yards of RAAMmat Ensolite IUO Peel and Stick
This should be enough for front doors and a trunk, maybe some on rear doors as well.
2. Specs:
RAAMmat BXT II
37.5 sq per box flat pack box, just a bit more than our competitors "comparable" products.
60 mils thick (.060", check the weight to thickness of the other products on the market) we have found that to be the perfect thickness to provide the amount of deadening most areas need.
24 sheets, 15"x15", 40% denser than BXT at .52 lbs per sq ft, (engineered to go up against the top brand mats on the market)
4 mil soft aluminum finish (softer aluminum to help prevent cuts while installing, hard aluminum like others use has been known to cause serious lacerations.
250 degree temp rating (any higher rating is a moot point, the vehicle would already be on fire so we shoot for realistic numbers and spend our resources on making the performance better instead)
This will help make for a faster install, lessen any chance of getting adhesive on costly interior parts, etc....
14 sq ft per running yard, 56" wide!
This is a very high grade foam/adhesive combination that will handle high heat, is fire retardant just like regular IUO and is stretchable enough for easy install.
3. Description/Condition:
Brand new in box
4. Price: :
100 shipped for all
5. Pictures
crosjr
crosjr
Tampa, FL
crosjr
