"double input" ring terminals...
ThatChevyGuy
sue me, its a ford.
Okay, first off im kinda in the gray area when adding a second battery, but i know how to do it. i usually just use 4 ring terminals (2 on each batt terminal) However, these seem like they would make my life more simple. Am i correct at assuming that these will allow me to insert my power wire from my front battery, and have a run out to my amp at the same time, from my secondary battery? Or are these just input OR output. Dumb question i know, but i don't want to blow **** up.
Xscorpion RT44P Platinum Plated 4 8 AWG Gauge Dual Ring Terminal w Adapters | eBay
Those terminals linked are more so intended for doing double runs of wire. Remember if you buy those terminals for your wire, you will still need battery post terminals to attach them to, unless the battery uses those side bolt terminals.
Avoid those at all costs. Had them and the set screws stripped out super easily, couldn't even get a good grip on the wire and it kept coming out. Come on over to MAF and we can get you some ideas.
were they tapered on the inside? Some people say the wires come out due to the stupid tapered designed.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
ThatChevyGuy
