"Breaking in speakers" General thoughts
Thanks! Found it
I searched previously and there were too many pages in the list... appologies
No problems at all.
If you read through you will see that I had some test results that initially would support the idea of "break in" in the since of needing to be easy on the driver at first. However, after I cross referenced some test results I found that was not the case and it was a factory fault causing the issues.
In the end, "break in" in the since that you need to take it easy at first, is not true.
West
Banned
West
Oliver Springs, TN
sacsking916
