RAM_Designs
SketchUp Master
- Thread Starter
- #16
Right. The one I have right now can do 20amp at first and then as the voltage of the batt gets higher it will step down the voltage a little until it goes into a 2amp charge that will raise the voltage the last bit. I guess the issue I am having is the best way to maintain a large bank of large batteries. I'm working on getting a load tester as well, so I can ensure proper function and ability to recover and hold proper voltage. I assume that I can just manually do slow charges every once in a while to keep voltage up without having to invest in a tender.Batteries charge best with a small amperage charger. The idea of a tender is not to charge a dead batt, it is to maintain one. If your batt is dead, its still best to recharge it with a 1 or 2 amp charger, unless you need to use the batt soon. But charging your batt with a 1 or 2 amp charge will give a deeper charge over all.
Most good chargers will step down their output as needed, but they wont ever shut themselves off completely. That is the difference between a tender and a charger.
