this is how one of my boys ran his 2 amps to his subdo the amps have to be the same? does it matter? in my case ill be using the same. so ill piggyback the amps together and just run the ONE set of rca's to the deck. would that be okay?
some amps have both an input and an output on them..i believe its fine as long AS the amps are exactly the same....and the gains are matched also. you can just daisy chain both amps if your amps have input/output on them and not just input.i dont think thatd work because if theres only one set of rca's one of the amps wouldnt be getting a signal from the head unit
theyr the rca's to the head unit, but yea ive only seen this done once so my knowledge is limited in this area, i just seen how my friend wired it and his sub hit hard so i was just puttin in a lil info to try n helpwell in your diagram, what are the 2 leads from each amp going to ur headunit mean?
also, i think "piggy backing" is fairly common. as long as one amp is connected to the other it shouldnt matter. its just i never seen someone piggyback amps to ONE sub before. maybe thats different . im not sure!
