tmorales509
I was just wondering this but as far as like my electrical system. Would their be much difference from wiring for a 4ohm load with the gain at like 90% and 1ohm load with the gain only like a quarter of the way?
The reason im asking is because i had a amp taht was 650watts @ 4ohms, that is how i had my subs wired. I bought a new amp but its only 500 watts @ 4ohm which is not enough, you cant wire two dual 4 ohms to a 2ohm load so the next thing would be 1ohm which is 1500watts. I don't want 1500 watts since the subs are only 600watts total. If i wire to 1ohm and just keep the gain down as opposed to 4ohm load with the gain almost all the way up. Would it be a big difference on my electical system?
I figued on my old amp at 4 ohms i had to get about 50 volts ac on my dmm to get around 650 watts, to get that on a 1ohm load i would only have to get around 25 volts ac. So does taht mean i would actually be using less power on my electrical then before or what, i not sure how to figure that out?
