quick question
85_blazer
i was wandering what should be my first electrical upgrade. i want to get a h/o alt. i also want to do the big three. should i wait to do the big three until i get the h/o alt? or should i just run a extra battery to the back then do the other stuff? i want to run a ma audio hk4000 or a mm4000.
my opinion is Big 3 now, then upgrade your front battery, then depending on the amperage of the alternator you have now, add a battery, and then a H/O alt.
reason being is cost, do the things that will make a big improvement at the least cost and then work your way up. you may find you don't need to do everything, big three and a deep cycle battery may take care of it.
When you do the big three also put a 0 gauge from negative directly to a different spot on the engine block it helped my voltage .3 on top of the big three.
85_blazer
85_blazer
valparaiso IN
Thedeadly1
