Quick question ( subs amp )
h2h0e
What you guys think is better for my electrical system and performance :
SHould i buy 2 dvc 600 rms (2 ohms ) and run my amps at 2 ohm
or buy 2 dvc 600 rms (4 ohms ) and run my amps at 1 ohm
Here my amp spec :
Audiopipe apsm-2000 Power :900W @ 4 Ohm rms
1400W @ 2 Ohm rms
2000W @ 1 Ohm rms
( i know my amp dont do the rated power so let say it does what it say -25% )
ohm load doesnt matter much if your running the same power reguarless. id wire to 1 ohm just so the amp gain would be as low as possible
OH ty and do you think i will need to upgrade my electrical system if im running my amp too 1 ohm witch will be pulling 1000 rms )2x 500 each sub )?
rite now im 4 gauge + i did the big 3 upgrade and my alternator is pulling 90 amp and i got a factory battery
at 1k rms i would definately wire to 1 ohm. if the big 3 and power/ground is all decent 4g wire you should be fine, only pulling 70-80 amp, may get dimming at idle.
Yea well thats my next question lol : do you know a good 4 amp kit on ebay witch i suppose is ofc ?
h2h0e
h2h0e
canada
h2h0e
