Quick question, plz help!
if you are going to be removing your sub alot of times then it is recommended to have T-Nuts. It is to prevent splitting your wood. But basically you just tighten your sub on to the box by using your screws and inserting it in the sub screw holes and drilling it into the box.
unless you want to mount the sub on the box and then using a marker to mark each spot and pre drill from there.
dustinr
dustinr
Moberly, Missouri
danteBirosel
