Quick question on relays.
Nico Koutouzis
Hey guys I have a quick question. I cant move on with my build until I get the relays but im kinda lost. Anyways I have a pioneer avh 4300 and lots of accessories that need power such as tv's, headphones (car), an more. I plan on running a 10 gauge wire to this multi output distro block Tsunami TSFDB-14ATM Power Hub Distribution Block , Here is exactly what it will be powering.
-3 TV's
-Video Signal Amplifier
-Car Headphone transmitter
-LED control box
-Remote Wires for amps
-Reverse Camera
Now my real question is (since the g35 doesnt have a wire in the back that turns on with ignition, just a hot wire) I has going to hook up a small relay to turn on a big relay for all my accesories. The little relay will have the remote from the back of the headunit and will use the hot wire to turn the larger relay on. Now finally for the question. Do I need a second relay to run all these accesories? Or will a decent one flip the 10 gauge hot wire in the back using the remote wire from the HU and run all this power?
CN: I have a 10 gauge hot wire in the trunk. Will the remote wire from the HU give a relay enough power to flip it and run all those accesories^^^^^?
A typical 12V automotive relay (Radio Shack) can handle 30 amps through its contacts and can be driven directly by the remote on your HU. I always recommend a reverse diode across the relay coil to protect the HU switching transistor from voltage spikes.
You absolutely MUST use a quenching diode (1N4001 will suffice - cheap and easy to find) across a relay. I recommend a transistor to drive the relay, but a remote wire may be able to drive a relay on its own.
uhhhhhh im sorry im new to all this relay stuff..... what r u guys talking about exactly?
---------- Post added at 04:37 AM ---------- Previous post was at 04:37 AM ----------
and where can I get this stuff
links/pics of what ur talking about would be awesome. Also can u solder 8 gauge wire to these things? (not that 8 gauge should be soldered like regular wire. I just dont have 10 and i have 8 so why not)
Nico Koutouzis
Nico Koutouzis
Hartford, CT
dragonrage
michigan born
    May 14, 2026
michigan born
    May 14, 2026
