quick question on multiple woofer wiring options
  • 4
wait - are you saying 24 subs in total or 2 subs in total?
just for f*cks sake if you are talking 2 subs the final load would be 0.667 ohms , but like I said you cannot (should not) run different subs on the same amp
Is it possible that you type your whole question out and not just parts of it?
"Here you say you want 12 - 4 ohm subs and 12 - 2 ohm subs = 24 subs total."
What is your question exactly?
Yes omega is right lol I thought u guys would get it that's the question I meant I meant between 12 woofers what are the wiring options for if they were dual 2'svand dual 4's
what ohm load would i get with 12 dual 2 ohm and 12 dual 4 ohm woofers
using an "OR" instead of that "AND" would have made it much more clear.
What ohm load are you looking for? There are tons of different answers but knowing what you are looking for would make it much easier to decide?
Are you looking for 1 ohm .5 ohm?
If you go with Dual 2 ohm's
wire 3 sets of 4 subs in parallel = .25 per set of 4
run those 3 in series and I believe you will have a .75 load but someone else should check that as the only thing I am not 100% sure on is what happens when you series 3 .25 ohm loads (I think the answer is .75)
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
i have no experience with component speakers. Maybe someone else can help in this area.
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
417
jaeguerra909
jaeguerra909
ontario,california
>>SQL<<
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
