Quick Question about wiring through the box
BoondockSaints
How do I do it? lol... Should I buy a terminal cup or drill a hole? I don't have an amp for my subs yet or any wiring I just wanted to build the sub box while I had a chance and the one part I totally forgot about was the wiring. I need to figure it out before I glue it together so I dont have to cut anything at an awkward angle....
I want it to come out of the side but Im not sure what Im supposed to use or do here...
3 options I see drilling and runnin wire through then caulking over, buy a terminal cup, drill a hole put a bolt through it with nuts on each end, wrap wires around nut and yah you get the point. Drill hole and caulk over seems to be the easiest... any other ideas though
I'd usually use a set of binding posts. Gets a great connection and the wires can be removed easily. I just like these more than terminal cups because I don't like trusting my connection on a tiny spring. But, it's all up to you.
Here's a link to a set I have used before.
Swick
BoondockSaints
BoondockSaints
DFW, TX
prodgod
