Quick ohms question.
  • 4
The sub channel on that amp can do 420 watts rms on a 2 ohm load, or 210 watts rms on a 4 ohm load. So to get the most out of it find a sub with a 2 ohm resistance.
This can be either:
-1 single voice coil sub with the coil at 2ohms
-1 dual voice coil sub with each coil at 4 ohms (wired in parallel)
-2 subs each with a 4 ohm load (wired in parallel)
-2 subs each with a 1 ohm load (wired in series)
probably should look for a dual 4 ohm sub...that amp puts out 410 watts at 2 ohms
Thanks Bones.
RMS Power (4 ohms) 70 watts x 4 chan. + 210 watts x 1 chan.
RMS Power (2 ohms) 85 watts x 4 chan. + 420 watts x 1 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 130 watts x 2 chan. + 420 watts x 1 chan. (at 2 ohms)
With these specs I wasn't sure if I had to run it at 4ohms because I'd be running the speakers all at 4ohms. So I guess I can run the speakers all at 4ohms and the sub at 2ohms?
Thanks Bones.
yes sir that is correct
This can be either:
you forgot the famous dual 1 ohm sub:crazy:
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
991
i have no experience with component speakers. Maybe someone else can help in this area.
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Beerdrnkr
Beerdrnkr
San Diego
bonesninja
    May 24, 2024
    May 23, 2024
