quick check before i buy
bigk1121
20
ohio
hey i just wanted to make sure all this stuff is compatible with each other before i buy it an is there any thing that i am missing.
here is links to all the stuff.
hu - i bought a jvc hu already
2 subs - Rockford Fosgate P2D2-12 (P2D212) 12" Dual 2 ohm Punch Stage 2 Sub
box (i might build my own im not sure yet) - Ground Shaker NP 2 12 Dual 12" Ported Pro Subwoofer Enclosure
amp - Power Acoustik RZ1-2300D (rz12300d) Monoblock RAZOR Class D Car Amp
amp kit - http://www.sonicelectronix.com/item_18411_The-InstallBay-AK01.html
installation kit for my car - Metra 99-2004 (met-992004) Installation Kit for Select 1996-2002
It will work (if you want to call it that) together. You also need a wiring harness for your vehicle so you can connect the head unit. You also put the wrong link for whatever amp kit you're looking at. Just make sure it has a set of RCAs with it as well as the other wiring. Any reason you're looking at those specific items? You could do better for you're money. What kind of budget are you working with? And if you have the tools and ability, there's no reason not to build your own enclosure. Just about any prefab is going to sound like sh*t. For $85, you could get all the materials you need to build an enclosure, with cash left over; or spend a little bit more and have someone build you a proper box.
srr about that i had the amp for the amp kit lol i added the amp kit. an that is jut the stuff that looked good to me for that price but im new to car audio. so if you got any suggestions im all ears. my budget is around $500
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
i have no experience with component speakers. Maybe someone else can help in this area.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
bigk1121
bigk1121
ohio
Bwap
