Question running 2 batteries
Just installed new yellow top optima and still experiencing voltage drop. It has lessened with the new battery being in And my lights don't dim as bad. I haven't been able to get my DMM on it yet to check how low it gets but from the dash gauge it looks to be dropping between 11-12 assuming the gauge is accurate.
Basic checklist for better voltages
1/0 Big 3 with solid bare metal grounds _?__
good battery under the hood __V__
add a 2nd battery to the back ____
High output alternator ____
Not sure what size your stock alternator is right now but check to see if its healthy because you shouldn't get that big of a voltage drop with that little power draw.
if your having headlight dimming issues even with voltages above 13.8 it would be better to get a set of HIDs
1/0 Big 3 with solid bare metal grounds _V__
Big 3 done with 2/0 welding cable
Haven't added a 2nd yet
High output alternator __V__
Stock 105a alt went out last year so upgraded to 145a alt.
I have HID headlights and fogs. I notice the dimming in my dash cluster and my taillights
i suspect something else may be going wrong, within your electrical system because your hardly putting a load on it. what are your voltages reading? get a number reading from resting, one from idle, one from reved up, one with audio on and full blast and let us know
I went to have the alt tested this morning and it passed. I haven't done the readings from my batt cause I wanted to rule out the alt being bad first. And on my way to the parts store I noticed my voltage wasn't dropping as bad as when I first put in the new batt. Could it have been that the battery wasn't 100% from sitting on the shelf for a while? The date stamped on it was 05/13 so is 6 months enough to make the battery not 100%? Im guessing the alt charged the battery a little bit and now my voltage drop is only happening at idle. I'll post a reading of my voltage with my system loud at idle and see how low it gets.
You need an alt, I'll be the one to say it. 105 amps to run everything you have isn't enough. I have 140 amp alt and half the stuff you do and my lights dim. When I put subs in I will be adding a new alt, I suggest you do that first before you kill your equipment
My alt is a 145 amp. The stock was 105 amp and when I was running 2 subs on the stock alt I never had a problem with lights dimming or anything. Once I got the other 2 subs in that's when I started having voltage issues. I'm gonna go back and double check my sub wiring cause I don't remember how I wired the newer subs
**problem solved!** //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
My dumba** had the subs wired to 1ohm. Rewired them and tested them out and no more voltage drop. Lucky for me I didn't destroy any of my equipment. Next time I'll try to be a little more sober and get it done right the first time
robbierob02
robbierob02
Phoenix, AZ
robbierob02
NorthFramingham
    Jun 30, 2026
