Question on which amp or both
I'm already running off the alpine, which is seeing a 3 ohm load per channel, with db okur a71001.1 which was used for a jl stealthbox that I changed the sub in it to a dvc infinity and also a jl audio 10 tw3. I am replacing the stealth box with a custom made center console with a w7 inside, and switching the db okur a1100.1 to a Rockford T1000. The vehicle is an 08 Sierra extended cab. One set of components in front door other in rear. I know I can bi/amp the components, but will I loose spl and gain sql with the addition of the second component amp. Any advice on which way to go would be appreciated. Thanks
Minkos6
Minkos6
North Huntingdon, PA
Minkos6
vegang
vegang
