Question on speakers
GrandPrixDriver
Grizzled.
I got the two front speakers of my car blown out and I took the door panel off and checked the size of the speakers and they are 4X6 but they're square speakers. I want to put the Pioneer Ts-G4641R speakers into my car. It says they are 4X6, so wouldn't that work? If not, what would I need to do so they do work.
Thanks.
So your saying the back seat speakers. I can't just put these in the front seat because that is where my speakers are blown out?
You can but they only fit in their current state in the back deck. You will have to make a baffle to mount them in your doors. Look into "4x6 plate speakers". That should solve your dilemma.
Those should work but you still might need to make a baffle to make them fit your door panel. Its not a big deal, cut a piece of MDF or particle board to the right size and try to make it so your grills mount flush. Most aftermarket speakers sound better with a baffle or an enclosure to seal out the free air behind them.
Alright, I will try that thanks.
no, the "plate" is built onto the speaker for moutning in the OEM holes. I agree, a true 4x6 plate speaker would be nice up front, as long as you have larger drivers in the rear or kicks to give you midbass. the 4x6 plate has a 4" mid and 1" (or smaller) tweeter. Like this:
The plate is universal for most 4x6 mounting points, and gives you the benefits of a component set in the space of a 4x6. I second this recommendation.
GrandPrixDriver
Grizzled.
GrandPrixDriver
St. Cloud, Minnesota
keep_hope_alive
NorthFramingham
    Jun 30, 2026
