Okay, well I have a ZX350.4 and a set of PG RSD components. I want to run this amp bridged at 4ohms to get 175 x 2 @ 4ohm.
Problem I see is it's essentially 2 amps, so it has 2 sets of RCA inputs and 4 sets of speaker outputs.
The problem is how can I do the RCA's so it only uses the front stage RCAs, like, can I just put the left RCA on the left for amp 1 and the right RCA on the right for amp 2?
Kind of like how you bridge the channels, would it be the same?
Sorry if it's a bit unclear but I'm not sure how else to explain it. Any help will be greatly appreciated!
Thanks!
Thanks!
