question on putting sub in box and a leak in sub (PICS )
Hmmmmm can you get some bracing in there or no?
where?
about 5 posts up you can see the blue prints of it and the white pieces are the " supports " of the entire thing, but what do you mean
Man...Get som Gorilla Glue or some Liquid nails, and go over every crack you see.Take that sub out, and do the same inside, and call it a day.Run that enclosure till it falls apart.IMO.Seal that joker inside and out:uhoh:
Gorilla glue expands in the cracks, so it should seal , and it is an apoxy adheasive that will allow the structure not to seperate.I always use Liquid nails inside, and outside my boxes, to seal with.It is cheaper than Gorilla glue, but it will work too.
The pressure is pushing that box apart,so it needs some kind of apoxy , or ? to keep the box/ joints from expanding, since it wasnt properly sealed, it will hold it together, and it prob wouldnt hurt to go around the box one day and counter sink some SCREWS to hold that box together,
Tek18
Tek18
KY
hispls
