Question/Help
TRiCK
Ok, quick background information.
I have 2 12" Alpine Type R's (4ohm) hooked up to an Alpine MRP1000 amp.
I have it so that both voice coils on each sub are on, but still come out to 2 ohms so that the amp is still doign 1000 @ 2 ohms.
Today I was driving and the bass turned off randomly, but came in and out every 30 seconds or so, then after 5 minutes, went off completely.
I turn my car on, the amp turns on. The light on the amp is lit up.
I hooked up my subs to a friends car, and they still work.
Although my fuse under the hood looked fine, I replaced it.
I checked all the 25 amp fuses in the amp, they are fine.
I checked to make sure all wires are plugged in. Both amp and deck.
I'm stuck now, I have no idea what to do.
Is my amp fried? Although the light comes on.
is it a GOOD ground?...
4awg, attached to a sanded piece of metal.
I havent checked it, but I was asking, wouldnt the amp NOT turn on if the ground wasnt connected?
I mean, the amp has to have a + and a - to turn on.
Tell me if I'm wrong please, I just want this fixed.
^ you are thinking the same thing as me. Alpine only makes type r's in dvc I believe. This means that they CANNOT be wired to 2 ohm. They can only be 4 ohm or 1 ohm. He simply has them wired in parallel down to 1 ohm and his amp is going into protect. Don't turn it up as loud or turn the gain down.
yeah I figure he had it wired to 1 ohm and it would keep turning off on based on how hard it was pushed. Alpines will do that. It had enough and failed.
I prolly did wire at 1 ohm thinking it was 2 ohms.
Now that I think about it, when I did turn it up too loud it'd go into protection mode.
Yea well the amp is fried.
Here are my choices.
Either send it in and pay $70 + shipping to get it repaired or maybe buy a nice used amp, like the Memphis st1000d thats for sale in the classifieds for $150 shipped.
TRiCK
TRiCK
Maine
TRiCK
