Question. Haven't been able to find an answer yet
Dannysoundnoob
Oregon
So here's the skinny. I got 2 kicker 6×9s that need rms 90 watts so I got a suitable 2 channel amp. They are multi driver units and I'm replacing the factory ones that had two separate speakers with a positive and negative for each. So can I combine the positives and then the negatives and run that into a line output converter then to the amp on a single channel and do that on both sides or will that cause issues. I dont see a problem with it theoretically because the speakers have internal crossovers, but I just want to make sure before I go cutting wires. Doodled diagram attached.
What vehicle is this? Does it have an upgraded "premium" amplified setup?
Factory everything and you just want to add a 2 channel amp with 2 kicker 6x9s?
Is this a front door?
That "connector" isn't a splitter? It has 4 in and 4 out? Or 2 in and 4 out?
Its a 96 328i bmw. I dont believe it has premium sound. It does have a hifi/lofi switch. I've added some 12" subs in the trunk. The front sounds fantastic the 6x9s go behind the rear seats. I am planning to use a 2 channel amp because the speakers require more power thenthe stereo can provide. I tested joiningthe wires and it sounds great at low volume but starts clipping as you turn it up from insufficient wattage. The connector is a 4 pin in 4 pin out
I did some testing awhile back so I know one set will only supply the 3way speaker with tweeter frequency and the other set only the woofer, then I soldered them together and I got full range just not enough power.
580
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
868
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
657
Dannysoundnoob
Dannysoundnoob
Oregon
Dannysoundnoob
    May 23, 2024
    May 22, 2024
