Question bout amp, wireing.
DeViOuSoNe
What's a Subwoofer?
This question makes me feel a little stupid...haha, But I really want to know. So here it goes.
If you have a 2 channel amp can you wire a channel to each voice coil on a sub? So have Channel 1 going to one voice coil, And channel 2 going to the other?
Also could you do this with a mono amp?
Someone Learn me...lol
Yes that is how you do it with a two channel amp
the amp will see each coils ohm's so if you have a dual 4 ohm sub each channel will see 4 ohms. Now if you wire a mono amp to each coil on the dual four sub the amp will see either a two ohm load or an eight ohm load since you are combining the coils.
the12volt.com can help with this, look under box calculators
Yes that is how you do it with a two channel ampthe amp will see each coils ohm's so if you have a dual 4 ohm sub each channel will see 4 ohms. Now if you wire a mono amp to each coil on the dual four sub the amp will see either a two ohm load or an eight ohm load since you are combining the coils.
I forgot to mention that there is a good chance that you can bridge your two channel amp which usually gives you more power and turns it into a "mono' amp. This is usually the best option for a two channel amp.
DeViOuSoNe
What's a Subwoofer?
DeViOuSoNe
MD
questionaire
