Question about wiring my amp...
Ok i really need some help here, try to stick with me haha.
I have a Kenwood kac-9102d amplifier, powering a 12" kicker L7.
The amp puts out 500 watts rms at 4 ohms, and 850 watts rms at 2 ohms. The kicker runs at 750 watts rms. I had this set up in my Saturn Ion Redline wired to 2 ohms and it BUMPED! Heres the problem...
I put my Redline away for the winter so i figured i would put the amp and sub in my Saturn Vue for the winter. I have it all wired up to the stock radio and it works perfectly until i turn up the volume quite a bit. The thing is that i used a lower grade power/ground cable that i thought would still work in the vue. When i turn up the volume it works fine until there is a big hit of bass and then it cuts out and the light on my amp turns off for maybe a second or two. It does this everytime the bass gets loud. I think its protection mode but i'm not sure. I really dont feel like buying and running new wire. If i wire the sub to 4 ohms will it not cut out as bad? I want it to be loud like in my redline. I'm not sure it's the wire but i dont know what else it would be since its the only thing thats different from the redline. Will a capacitor help? Is there a better way to wire the sub? Any help or suggestions will be appreciated, Thanks!
Heres the difference in wire...
Redline: http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
Vue: http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-K4
your voltage is dropping, bad. Wire should be fine for that amp...check your grounds and connections
sounds about right.
could be wire though. i had this problem once.. and it got fixed immediately after i upgraded from 4 gauge to 2 gauge
but check all other things bfore you go get new wire
Somebody also said, "If the radio cannot supply enough signal the amp can't get a grip on it and crank it up. (All has to do with gain ratios).
Sounds like the radio isn't giving the amp a large enough signal."
Could this be the problem?
nickster914
nickster914
Cold Spring, MN
nickster914
