question about using RCAs
CharHer
I have a 4 channel amp running front and rear speakers. My question is should I use a 4 channel RCA for the 4 channel amp or would it be better to use 2 2channel RCAs?
these are the ones im planning to purchase - KnuKonceptz Karma SS
4 channel - http://www.knukonceptz.com/productDetail.cfm?prodID=KARSS4.6M
or
2 2channel - http://www.knukonceptz.com/productDetail.cfm?prodID=KARSS2.6M
thanks
oh and one more question. Does the lenght of the RCA affect sound quality? I drive a mazda 3 and the 12 ft is not long enough to reach from my deck to the trunk. i have to use 18 ft.
If your amplifier can operate all 4 channels with only 2 channels of input you can do that......but you'll lose the ability to fade front-to-rear. If you want to retain your fade you will need to use both the front and rear outputs on your headunit and the 4-channel RCA's.
No.
or
thanks
A 4 channel 18 ft rca is the same as two 2 channel 18 ft. RCA's.
If using identical brand of RCA's, either would be fine.
CharHer
CharHer
Toronto
Hayabusa
michigan born
    May 14, 2026
michigan born
    May 14, 2026
