Question about underpowering a sub
you're going to be grossly underpowering that sub. and you only have 1? you'll have channels on your 4 ch not even being used then. let's assume these ratings are actual ratings (i don't like audiobahn and i don't) then you have 1 sub with dvc 6 ohms and 1 4 channel 75x4 amp. your wiring options are either 2 x 6 ohms or 1 x 3 ohms. your sub voice coils have the thermal capacity to handle 1000 watts. your amp will put out 225x2 @ 6 ohms and that's the only thing it is safely rated at. this is fine if you aren't trying to max out your sub but if you want some real pounding from that think you 100% need a better amp (not recommending another audiobahn either)
I have the alum12X which is also "rated" at 1000 rms. Im powering it with the a18001dq audiobahn amp @ 3 ohms, "supplying" 900 watts rms. I dont care if audiobahn inflates their numbers, it is getting enough power, and the sound quality on this sub is pretty **** good for the $60 i paid for it. (.88 sealed box btw)
Now,all you need to do is change that stupid user title //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
396
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
757
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
998
Alum12Q
Alum12Q
Wausau, Wi
supa_c
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
