question about tweeters
BRZguy
hey guys, im planning to go active when the 9887 come out. i have a question about the tweeters i have tho. im not sure but do tweeters have a rms and max watts? i cant find anything related how much watts my tweeters can handle. i dont want to blow them. this is the only info i can find on the web. i still lots to learn, so if you can help me out that be great. thanks
* Impedance: 4 Ohm
* Sensitivity: 93 dB 1W/1m
* Frequency range: 820 Hz - 25 kHz
* Resonanace frequency: 820 Hz
* 25 mm vented high end tweeter with drilled 2,5 mm neodyme plate
* 25 mm silk dome
* coupling volume 18 ccm, filled with 1,1 g of damping wool
I wouldn't worry about the MAX wattage rating anyway. When a speaker mfg rates a speaker's max wattage is only for peaks or split second bursts of power. By no means does that mean you should pick an amp based on PEAK or MAX ratings of a driver. When pairing an amp with drivers the only thing you should match are the RMS ratings of the amp and the speakers.
thanks. i just want to make sure im not giving the tweeter too much power.
BRZguy
BRZguy
socal
BRZguy
vegang
vegang
