Question about S/N Ratio
i can't wire them different because they are single 4ohm voice coil and the amp isn't 1ohm mono stable. I play it 1 hour and it was cold like ice, it don't get even little hot. Is that normal.
now they are wired like that:
one to the left channel and other to the right channel. The subs are single 4ohm voice coil each. And the amp isn't stable at 2ohm mono.
No i can't wire that because:
Amp is 2ohm STEREO that mean each channel is stable at 2ohm but in bridged mode with two 4ohm vc wired in parallel to get 2ohm, each channel will see 1ohm and the amp isn't stable at 1ohm. I'm 100% sure of that.
AsK 5109
I GOTTA LOTTA MOE!
AsK 5109
Yorkville, IL
bobomanta2
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
