question about power wire
yeah it's not gonna i'm just saying if it fell out from the fuse holder or something which would sound like bad
Tie Strap or tape the wire down where it can't move out of the fuse holder... If it comes off the battery then nothing to worry about really.. no power its a dead wire..
yeah i did that but alright thats what i thought with the dead battery thing. i just didn't wanna ruin my amp/start my car on fire it'd be a boner kill
Battery is where the power is... if it come loose from the batter.. or holder the amp side will be dead wire... just do like i said.. tie straps.. tape etc.. as close to the holder and battery... if you are worried about it that much glue some rubber to the metal around the holder and battery man...
the only thing you have to worry about is the wire from the battery going into the fuse holder coming out, which is the reason for fusing as close to the battery as possible, usually less than a foot. If the wire comes out of the fuse holder between the fuse and amp, it is dead anyways.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Some at DIYMA and other places have tried this Oscilloscope as well and got good results shockingly for such a cheap unit...
jsluss17
jsluss17
Scottsdale, AZ
quackhead
slater
    May 2, 2024
slater
    May 2, 2024
