spencer321
is it true the less cabin volume you have to fill the easy it is to score higher?
i got 6.5 cubic feet below the window line... thats not enough? i could take it to the roof and wall it off, gets me 10cubes... i would "hope" that enough but maybe its not?If you do a cut through you will have an advantage.Otherwise, you dont have enough room for a good enclosure.
yeah my mustang and my prelude both sounded louder windows up doors closed not "big" noticable but with the truck... dear god if you have it cranked to what you think loud is with the windows up doors closed, and then you roll down a window its UNBEARABLE rolling the windows down or opening a door makes a HUGE differenceanother thing with the reg cab truck is even you crack the driver side door, and play low freqs it had a huge gain, same with windows down with like 45hz or so. but in the civic and honda fit, it lost pressure when it wasnt sealed up
depends on the subs, may not be enough.i got 6.5 cubic feet below the window line... thats not enough? i could take it to the roof and wall it off, gets me 10cubes... i would "hope" that enough but maybe its not?
well, 60 wide, 11deep 24 highdepends on the subs, may not be enough.Also, the shape and depth of the box is very important for SPL, and so is port design.
I have never seen 6.5 cubes in a single cab truck unless it is a shallow, wide box and that isnt too good.
